-> Thread split from https://linustechtips.com/main/topic/1055547-how-can-i-reset-my-pc-without-losing-installed-drivers
The original thread had been dead for year.
What is your actual question? Udating BIOS doesn't cause (usually) anything to Windows. Only thing you would need to take notice is what boot mode you are using now. MBR requires Legacy mode. Updating BIOS will reset all of its settings, but thats it. Windows should boot normal.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1201345-upgrade-bios-problems/#findComment-13653253
