Well it's out of stock now, but yes, it's a good PSU, but 750w is overkill. You could get the 550w or 650w version however, since those are in stock right now.
MAIN PC:
CPU: AMD Ryzen™ 7 7800X3D Motherboard: Gigabyte B650 Eagle AX CPU Cooler: EVGA CLC 240 GPU: EVGA RTX 3080 FTW3 Ultra RAM: TEAMGROUP Expert T-Create 32GB (2x16GB) 6000Mhz CL30
Case: CoolerMaster TD500 Mesh PSU: Thermaltake GF1 PE 750w Storage: 1TB Western Digital Blue 3D + 1TB Crucial P1 + 1TB ADATA XPG Gammix S11 Pro + 4TB Seagate Barracuda 5400RPM OS: Windows 10 Home
Headphones: Philips SHP9500s   Keyboard: Corsair K70 RGB MK.2 Cherry MX Red Displays: Gigabyte M27Q (27" 1440p 170hz IPS), Samsung UN32EH4003FXZA (32" 768p 60hz TV)
Former parts that I've used:  Intel® Core™ i3-9100F, Intel® Core™ i9-9900k, Asus Dual OC 2080, Gigabyte Aorus Master 3080, Gigabyte Gaming OC 3080, EVGA XC3 Ultra 3080, EVGA FTW3 Ultra 3080 Ti, EVGA 3060 XC, ASRock Z390 Phantom Gaming 4-CB, Gigabyte Z390 Aorus Pro Wifi, ADATA XPG 16GB (2x8GB) 2400Mhz CL16, Corsair Vengeance 32GB (4x8GB) 3000Mhz CL15, Scythe Fuma 2, Acer XG270HU.
https://linustechtips.com/topic/1200999-good-power-supply/#findComment-13650966
2 hours ago, James33 said:
https://www.newegg.com/seasonic-focus-plus-750-gold-ssr-750fx-750w/p/N82E16817151187
Is this a good power supply for a ryzen 7 3700x and 2060 super?
On amazon right now the seasonic prime gx 750w is on sale for back order when it comes in stock which is early June, might want to jump on it if you want a 750 watter, also you should seriously consider a 3600 and a 2070 super instead of your setup if your gaming, you’ll have a better experience.
https://linustechtips.com/topic/1200999-good-power-supply/#findComment-13651065
You also should problably just get a 650 watter because it’s in stock and if your not going to buy huge upgrades like a 3080 and a ryzen. 4900 when they come out, a 650 should be sufficient
https://linustechtips.com/topic/1200999-good-power-supply/#findComment-13651068
