Hi everyone I am custom watercooling my ryzen 2700x and I got a small amount of thermal compound of my cpu pin  my dad has built multiple pcs and I have built 2 he said leave it as the thermal paste has an extremely low conductivity I have since put it back in and mounted my waterblock. In your opinion will it work? I haven't booted it as I needed more fittings thanks for all your help
https://linustechtips.com/topic/1200995-help/
howdy and welcome :)
Probably.  Your dad looked at it and it sounds like he has some experience.  what kind of paste was it?  Many are not electrically conductive but a few are.
https://linustechtips.com/topic/1200995-help/#findComment-13650759
It was the wraith prism paste as I was removing it from the processor
https://linustechtips.com/topic/1200995-help/#findComment-13651704
He’s very likely right then.  I doubt AMD uses liquid metal or silver fill powder in their freebie paste.
https://linustechtips.com/topic/1200995-help/#findComment-13651885
Good news mounted my air cooler back on cuz the rest of the watercooling parts won't arrive until Monday and it's all working fine thanks for all your help and replies
https://linustechtips.com/topic/1200995-help/#findComment-13658845
