doesn't look so bad, from the photo
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1200782-damaged-dimm-slot/#findComment-13649463
5 minutes ago, JelloBeat said:
I mean, I didn't get the screwdriver anywhere inside the contact, so, it's ok I guess? Should I remove the plastic that got on the contact before putting the RAM stick inside?
possibly, the picture that is shown doesn't tell exactly what the type of blockage really is. Do you have a tool small enough to move the plastic?
Primary PC:
PSU tier list
https://linustechtips.com/topic/1200782-damaged-dimm-slot/#findComment-13649495
