Advice on pc
Go to solution Solved by 3rrant,
15 minutes ago, Casey j said:
Budget (including currency): 1300
Country: usa
Games, programs or workloads that it will be used for: civ5, planetside 2, cod, any type of games
Other : I had a pc planned but just about every time I got ready to order parts they sold out but I have the money now I just need a new build plan and i figured I'd ask for help I'm new to this and figured I make sure I do this right this time! I have a gameing laptop but its about 6 years old and I figured I'd invest in a pc I play just about everything so just needs to be able to play not looking to play on max settings! I did buy a case already but I came sell it if you have better ideas it's a NZXT H510 Elite - CA-H510E-B1 - Premium Mid-Tower ATX Case.
PCPartPicker Part List: https://pcpartpicker.com/list/nRQTx6
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($197.82 @ B&H)
Motherboard: Asus PRIME X570-P ATX AM4 Motherboard  ($149.99 @ Newegg)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory  ($84.99 @ Corsair)
Storage: Intel 665p 1 TB M.2-2280 NVME Solid State Drive  ($139.99 @ Newegg)
Video Card: Asus GeForce RTX 2070 SUPER 8 GB STRIX GAMING Advanced Video Card  ($584.99 @ Best Buy)
Case: NZXT H510 Elite ATX Mid Tower Case  (Purchased For $0.00)
Power Supply: Cooler Master MWE Gold 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.99 @ Best Buy)
Total: $1257.77
Generated by PCPartPicker 2020-05-26 01:47 EDT-0400
Unless you want to go for a 2080 Super which will add another 100-150$ to the budget or get something cheaper than the 2070 and wait for the 3xxx series release this year (probably a better bet)
Country: usa
https://linustechtips.com/topic/1200058-advice-on-pc/
Country: usa
Total: $1257.77
https://linustechtips.com/topic/1200058-advice-on-pc/#findComment-13643956
Case is fine.  Better than mine which is also fine. It can be worked with.  Civ5 and COD basically have opposite needs game wise so going for a
general system.  $1300 is sort of right on the edge between a belled and whistled high refresh 1080p and a lean 1440p. Do you have a preference?
UPDATE above list would be lean 1440p
https://linustechtips.com/topic/1200058-advice-on-pc/#findComment-13643965
Not really I'm down to go above my price range
https://linustechtips.com/topic/1200058-advice-on-pc/#findComment-13647615
If you’re willing to go higher price look to the 1440p stuff then.  1440p needs more monitor and video card to drive it.  1080p is often thought of as 1k while 1440p is thought of as 2k so driving 1080p@60hz takes 1/4th the gpu power of 1440p@120hz.  Monitors capable of the latter cost about 3 times what monitors capable of the former do.
https://linustechtips.com/topic/1200058-advice-on-pc/#findComment-13647630
