linux Linux: temperature control.
Solved by Wanderingturtle,
Latest update.
After going through Bios setting I wasn't able to adjust my fan speed, however I decided to install TLP And able to lower the temperature to around 60 degrees. Yes the fans ramp up a bit but that's fine by me.
Thank you for taking your time to answer my question.
Wild penquin, The flying squirrel.
