Would a 360mm radiator fit in my case?
Solved by Statik,
1 hour ago, IAmAndre said:Hmmokay so you're saying that the air from the two fans on the radiator should cool the radiator itself and the rest of the system?
Yes. The air will be a few degrees warmer obviously, but it will still (in theory) be plenty cool enough to cool down your system.
Featured Topics
GreenLeaf ·
Posted in General Discussion0 -
GreenLeaf ·
Soapy1234 ·
Posted in Peripherals1 -
Shutset ·
Posted in Programs, Apps and Websites2 -
Codrut1001 ·
Posted in Troubleshooting0 -
5
Cypher-Jackson ·
Posted in CPUs, Motherboards, and Memory7 -
Yousef65 ·
Posted in Troubleshooting2 -
2
2
