4 minutes ago, like_23_ninjas said:
If I added another case fan as an intake, will it make much of a difference?
yes but it's a difference you might not notice, unless your CPU fan is working really hard to maintain that temperature.
What about GPU temps?
Primary PC:
PSU tier list
How many watts do I need?
it all depends on your GPU and CPU and heat measurement inside the case...you should measure the temps of CPU and GPU and report us,if those are too high,would need intake fan,preferably at least 140mm.
Please do not take offence for my apparent confusion or rudeness,it's not intent me to be like that,it's just my BPD,be nice to me,and I'll return twice better,be rude and usually I get easly pissed of...I'll try to help anyone here,as long as it's something I dealt with,and even if you think I'm rude or not polite,forgive me,  it's not me it's my BPD.
Thanks for understanding.
