I have a MSI z87 g41 Pc Mate MOBO and ill be buying a Sapphire r9 280x Toxic but i have a problem.
when i measure the GPU in my MOBO i think the USB 3.0 cable will block my GPU. Is it true?
No, there will be no problem. Everything will fit.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
https://linustechtips.com/topic/119868-does-it-fit/#findComment-1597036
did you check the picture of my MOBO? MSI z87 g41 Pc Mate
Of course I did... Also the people who actually design these motherboards have thought everything. There will be not conflicting hardware.
https://linustechtips.com/topic/119868-does-it-fit/#findComment-1597073
