Budget (including currency): $2100
Country: USA
Games, programs or workloads that it will be used for: Gaming/streaming/recording
Other details Only thing I really have atm is a 165 MSI monitor. After watching a couple LTT videos I am interested in liquid cooling however I dont mind switching to air cooling. Im really just leaning towards liquid cooling for the aesthetics. I love RGB which you can probably notice from the list which brings me to my point: I have a pcpartpicker plan setup and I am hoping some of you can take a look at it and let me know if you would change anything seeing as this is going to be my first pc build ever. Keep in mind I dont plan to buy anything for another month or two. Thanks in advance for any help given.
https://pcpartpicker.com/user/Latharius/saved/dLt2Vn
https://linustechtips.com/topic/1198614-2000-build-plan-help/
You can get the 3900x from microcenter for $30 cheaper
CPU: Intel core i7-8086K Case: CORSAIR Crystal 570X RGB CPU Cooler: Corsair Hydro Series H150i PRO RGB Storage: Samsung 980 Pro - 2TB NVMe SSD PSU: EVGA 1000 GQ, 80+ GOLD 1000W, Semi Modular GPU: MSI Radeon RX 580 GAMING X 8G RAM: Corsair Dominator Platinum 64GB (4 x 16GB) DDR4 3200mhz Motherboard: Asus ROG STRIX Z370-E Gaming
https://linustechtips.com/topic/1198614-2000-build-plan-help/#findComment-13633501
@Latharius
😑 I don't understand the appeal of internal HDD's. Its performance is not optimal for gaming anymore, and any storage device connected to the motherboard can still be infected with well programmed malware, especially if the malware behaves like a worm. I'd just get an external 5 to 8 tb HDD so you can back everything up in case something happens that ruins your day, assuming you don't already have one. An internal HDD is of no use to you whatsoever when it comes to that.
System Specs
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
    Gigabyte AMD X570 Auros Master
  • RAM
    G.Skill Ripjaws 32 GBs
  • GPU
    Red Devil RX 5700XT
  • Case
    Corsair 570X
  • Storage
    Samsung SSD 860 QVO 2TB - HDD Seagate B arracuda 1TB - External Seagate HDD 8TB
  • PSU
    G.Skill RipJaws 1250 Watts
  • Keyboard
    Corsair Gaming Keyboard K55
  • Mouse
    Razer Naga Trinity
  • Operating System
    Windows 10
https://linustechtips.com/topic/1198614-2000-build-plan-help/#findComment-13633512
Wait, and ask for help when you're ready to build. Prices are fluctuating too much, especially right now.
Not only that, if you're waiting that long, you should be getting 4th gen Ryzen.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1198614-2000-build-plan-help/#findComment-13633516
