so i just upgraded my gpu and for no reason i lost all control over my audio interface and headsets, basically when i open youtube to watch something using my interface output it just shows a loading sign and never works unless i change my out put to my screen out put
plus my headset mic stopped responding as well i only managed to fix this issue in my digital audio workstation yet it glitches out sometime
i tried to reinstall the audio drivers for the interface and headsets drivers yet no hope
please help
https://linustechtips.com/topic/1198227-lost-control-over-audio-devices/
You need to set the sample rate of both Windows and your interface to the same number, 24bit 44.1KHZ is a safe bet, then disable all audio devices you won't be using. It's the mismatch in sample rates that has previously cause me the same issue but setting the sample rate to the Windows default (24, 44.1) fixed it all.
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
is there any guide on how to properly do them ?
they are currently both sitting on 48khz like they were in the first place
What interface are you using?
@rice guru
Just now, fallen01 said:
behringer umc 404hd
Yeah, that's the one thing with those Behringer interfaces, you have to be very careful with the sample rates.
If restarting the audio process doesn't fix it,
Set both the input and output sample rates to 24bit 44.1khz with spatial sound and enhancements disabled,
Use these exclusive mode settings.
It might not make much sense but trust me, it'll save you a lot of trouble (assuming you're having the same issue I did), also make sure you do the same for the inputs, if you don't the interface has a hissy fit and changes sample rates on you which causes the issue you're having.
Sloth
@rice guru
Sloth
i did that and still no fix
Assuming you've done everything I said, your interface is your defauly audio device and and the UMC control panel shows 44.1 the only other thing I can suggest is to restart audio process.
Press Windows key & R together then type Services.msc in the empty bar and hit Enter. When the Services window opens up, locate Windows Audio Services. Once found, right-click on the same and select Restart.
If that doesn't do it I'm sorry but I'm not sure how to fix it, perhaps someone else will but my only experience with this particular issue was fixed by following those steps.
@rice guru
yea still the same i mean as long as its working in protools im fine but is there any way to get my headset mic working im sure its not damaged or anything it happened when i upgraded the gpu the headset does output sound but it stopped inputting
You never said you were using a DAW, set the protocols sample rate to the same as your windows one and all I'll be fixed. Your DAW is at a different sample rate and because it takes priority on the interface Windows audio stops working if it's not at the same sample rate.
@rice guru
