Hey guys, so I wanted a fresh start with my pc so i went to windows system reset in settings and started the procedure. The pc starts doing it's thing and after a while starts reinstalling windows. so far so good. but when it was done the pc didn't start with the normal bit of privacy settings like normal but gives me a login screen. locked with a username and password. I have tried every username and password i have by my knowledge ever used but nothing works. can you guys help me? in the image you can ee the login screen i get when i boot up my computer.
https://linustechtips.com/topic/1198010-pc-reset-went-wrong/
maybe you've missed the user-password stuff when you install it.
since it was new, why don't you install it again.
https://linustechtips.com/topic/1198010-pc-reset-went-wrong/#findComment-13628633
Thanks for the help guys! The video did help me but after resetting the password it said that my account was deactivated and i needed to contact my administrator or something. So I stopped tryig to do that and just reinstalled windows. It is installing as I am writing this. I deleted all previous partitions on my bootdrive and it seems to work right now. Thank you guys for the fast feedback
https://linustechtips.com/topic/1198010-pc-reset-went-wrong/#findComment-13630063
