APC Back-UPS Pro 1500
Go to solution Solved by Guest,
That's not an online UPS.  The circuit through the battery is only used in the event of a power failure.  It will continue to charge regardless.  You can go ahead and plug all of your stuff in.
Hi, I just bought and had delivered an APC BX1500M battery backup for my computer. I have plugged it into the wall and installed the PowerChute software, but I have not plugged anything into it yet (other than the data cable to pair it with the software).
Does it need to charge or something for a period of time? I read through the manuals, and everything points to no, but I still remember when everything that had a rechargeable battery has to sit connected to power for at least 24 hours before being used. Is this still the case?
Thanks
https://linustechtips.com/topic/1197971-apc-back-ups-pro-1500/
