Hello
I have an old pc
System config
Intel core 2 quad q6700
Gigabyte GA-P41T-D3
8 GB ram ddr3 12800s 1600mhz
The Motherboard ram specs is 1333mhz
But the ram specs  I have is 1600mhz
The windows in the  task manager show me the ram mhz is 800 why ?
And what is the difference between ddr3 12800s and ddr3 12800 without the "s"
https://linustechtips.com/topic/1197956-ram-compatibility-problem/
1. Dont read Task Manager, use CPU-Z. It will read half the data rate (i.e. the 1333 and 1600 rating you use) because DDR memory has doubled data rate over its actual operating frequency (DDR = double data rate).
2. S typically means SODIMM, which is a shorter variant of memory sticks used by laptops and rarely desktops. I dont think this is the case so not sure.
Desktop benching:
Phone: Pixel 3a (Purple-ish).
Build Log:
