https://www.lian-li.com/o11dxl-1/
Google is spectacular.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1197863-vertical-gpu-mount/#findComment-13627449
9 minutes ago, OCrax said:
Lol, this is the one I bought previously but it was too large and I kinda wasted my money...
You don't have the XL version of the case, so you're probably looking for this kit.
http://www.lian-li.com/o11d-1/
Be sure to QUOTE or TAG me in your reply so I see it!
CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15
https://linustechtips.com/topic/1197863-vertical-gpu-mount/#findComment-13627903
17 minutes ago, OCrax said:
would this hold a 2080 Super though
I have no idea. You could contact their customer service and ask.
And I was wondering if this was any decent http://www.lian-li.com/lancool-ii-1x/
That appears to only be compatible with the Lancool II case, which you do not have.
https://linustechtips.com/topic/1197863-vertical-gpu-mount/#findComment-13628050
