An update to my old post about pc not booting up, My pc refuse to boot up i change the PSU/GPU and even the ram check all connection is plug in right and still will not boot, and today i take the dd4 2666 and put it in my main pc and the rgb light came on but pc refuse to boot.  while in my old pc the rgb light will not come on/i used this ram for 2 years in that system. i even went and put in my dd4 3600 ram which i bought a last week and the ram rgb will not come on nor boot. so i am left thinking is it my motherboard or the ram. PLEASE HELP! IM LOST!
All of this was working fine untill i build a new pc and only took the PSU but i notice it wouldn't boot the moment i put the 1050ti in i even replace that with a 1070ti and still nothing, i then replace the psu with the one i been using for 2 year in that same pc and nothing. the 1050ti is 100% in working condition and my new pc detect it. so yea kinda lost here.
The Old PSU IS- EVGA 650W  80+GOLD
NEW ONE/REPLACEMENT -EVGA 500W White
https://linustechtips.com/topic/1197731-what-is-the-problem-with-this/
Hello! I assume you've read the no Post guide in troubleshooting?
Are you sure it's not your CPU?
Is the ram you've bought even compatible with your mobos?
Do you have a POST error code or beep pattern?
Please mark as helpful and informative so my profile looks better.
quote or reply to me if you want me to reply to you.
Thanks
the ram is compatible i used it on that cpu/Motherboard for 2 years and no post error or beep sounds
