Hi i just build a new computer now i have been playing on it for a week. But today when i turned it on nothing happened (also when i press pwr switch on mb) no beeps or anything its like the power button wasnt working. Next i took the motherboard out and placed it on its box to see if that worked.
The only thing that happens is the rgb from the motherboard itself turns on when i turn on the PSU.
Now i have my PSU here and my motherboard with its CPU cooler and CPU. when i press the pwr switch on the mb itself the still nothing happens.
These are the parts
asus prime x570-pro
650w PSU
3900x
dark rock pro 4
https://imgur.com/a/wA9H6ew
https://linustechtips.com/topic/1197274-pc-pwr-switch-not-working/
These are the parts
asus prime x570-pro
650w PSU
3900x
dark rock pro 4
is the front panel io all plugged in correctly?
                                               JOIN THE FIGHT AGAINST COVID-19 BY RUNNING FOLDING AT HOME!!
        have a look at the thread below if your interested:
Home gaming and general work rig: CPU: 2700x with stock cooler Ram: Corsair vengeance pro RGB 16gb GPU: RX570 4GB (upgrading soon) Storage: 1x 500gb crucial SSD + 1tb HDD Mobo: B450-F gaming PSU: Corsair rmx550Case: Corsair 275R
F@H rig (In office and used for work too) CPU: 3600 Ram: Viper 16gb ram Mobo: B550-Tomahawk GPU's 1x 2080 super 1x 2060 super Storage: SN750 1tb Case: PC 011 Air PSU: Corsair RM850 Fans: 6x Noctua NF-12
Remember to quote me so I can see your reply!
Always Reply with a question if you have one! 😃
while psu is plugged and switch to on, try shorting the power switch headers with a key or screw driver
fron left to right, top: pin 3 and 4
if it turns on; you got a bad switch, but they can be fixed quite easily, if you have a multimeter on hand.
if not, something not quite right with your psu.
why everybody post the spec of their rig here? i dont! cuz its made of mashed potatoes!
