Hello everyone, I have a question, when I turn on the "remove noise" checkbox, it ceases to record a microphone for me. If this box is not checked, then everything works fine. What could be the problem? tell me please.
Sorry for the translation, I used google translate )
https://linustechtips.com/topic/1197230-rtx-voice-help/
ticking that button turns on RTX voice, you need to change your mic to "RTX Voice" in all the programs you use it for.
https://linustechtips.com/topic/1197230-rtx-voice-help/#findComment-13622765
And of course since the point of it is to eliminate everything that isn't voice, when you want to check your mic works you have to actually talk.. taps and other sounds will be mostly cut away.
F@H
GPD Win 2
https://linustechtips.com/topic/1197230-rtx-voice-help/#findComment-13622887
