Appreciate any insight. Trying to maximize my case air-flow efficiency and a bit unsure about this one. I have two exhaust fans top and rear, and two intake fans in front. My dilemma is positioning the AIO radiator fan, which is front-top. Since the radiator is behind it, it's obviously doesn't have air to pull and blow into the case. So this does not bring much air into the top half of the rig.
Only thing I was thinking, was to position top fan as an intake to bring more air into the case.
Anyone have any suggestions for a more efficient fan set-up? Thank you for reading!
https://linustechtips.com/topic/1197011-case-air-flow-recommendations/
being infront of a radiator should still allow it to bring in air, given case layout. if you have to, I'd flip the top exhaust to be an intake instead.
At me or quote me, I want to hear your opinion.
Hopefully anything I say is factually correct. Sorry for any mistakes in advanced.
if it's single fan aio, perhaps try switching the radiator to case top as exhaust.
Please give kudos if you find someone's reply helpful 😃
In case you wonder about my forum name, it's either Cthulhu or two dwarves about to make out ;)
Now that you've seen it, can you unsee it?
Get motion sickness playing FPS =(
"You so ugly you scaring away the fish!"
>>> "BOOB JOB" <<<
Ryzen 3600
MSI B450m Mortar Max
2 x Corsair low clearance DDR4 8G 3200MHz C16
GeForce GTX 780 Ti (temporarily downgraded)
Silverstone FT03
Samsung EVO 2.5" SSD 500G (boot) + WD SN550 1TB (game lib)
WD Elements 3.5" HDD 1.5T (storage; pulled from an old external drive)
Seasonic SS-660XPII 660W 80Plus Platinum Ver II
DeepCool Gammaxx GT (CPU)
Silverstone AB120R (intake)
2 x Silverstone AP81 (intake)
Silversrone FN121-P (exhaust)
AG AGON AG323QCXE (What a hidden gem)
NiZ Plum Electro-capacitive Keyboard
Logitech G703 Hero Lightspeed
Koss Sporta
Windows 10 Pro
Linksys WRT1900ACS (rocking OpenWrt)
WD Elements 5T external HDD (network backup drive)
Yeah... I hardly think that top fan is doing you any good at all right now. I'd switch the radiator to the top, that way you get cooler air into the PC. If you can't do that because of space, just flip top fan to pull in fresh air over the VRM area. Least it will be doing something positive that way.
