Multi Monitor Youtube Problem
Max S
I have 6 monitors my main 3 are running on a 2080ti xc ultra and my other are running on a rx560. When I go to watch youtube on my main 1440p 148 hz main monitor It will buffer and not play. But this is only on youtube. please help
- also ived heard "YOU DONT NEED THIS MANY MONTIORS" A billion times so dont say it
Also now it will nut buffer when I close all my other crome windows but thats the point of having a 6 monitors in the first place
ok, you can have problems if you use different cards like that. basically what is happening here is it is rendering the youtube video on the RX560, and displaying it on the 2080ti, and that causes a massive amount of lag.
you can try disabling hardware acceleration in your browser, this will render the video on the cpu not the gpu, which will theoretically fix this problem but i've never personally tried it.
She/Her
LOL why would anyone say that? It's your decision how many you need.
Anyways, what kind of buffer are you talking about? Does it not load at all or just buffers a couple seconds more?
I've Personally had issues with setups containing 120/144 as well as 60hz displays too, what happens if you clock all of them to 60hz, just for testing?
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
Ok update. It works when i have 1 or 2 chrome windows (not tabs seprate windows of crome) open but when i get to 3 or 5 its starts to lag. And having multipe windows is the whole point of mulit monitor
