High-end fans are Noctuas, or if you want RGB, Corsair makes great fans.
I'm not familiar with the low-end spectrum though
"hi 911? my grandma is on the floor and shes not responding to anything"
"have you tried turning it off and on again?"
ding ding ding ding ding ding ding, di-di-ding
https://linustechtips.com/topic/1196542-fans/#findComment-13617324
1 minute ago, Goku1814 said:
i dont care about noise i cant possibly stand everything being quiet constantly
Then get some 10k RPM Delta fans, lol.
Either way, there's diminishing returns when it comes to cooling modern hardware.
It just doesn't produce enough heat to care so much about what fans you're using if you don't care about noise.
https://linustechtips.com/topic/1196542-fans/#findComment-13617332
lets be a lil reasonable i dont want my pc sounding like a jet lmao
https://linustechtips.com/topic/1196542-fans/#findComment-13617347
Just now, Den-Fi said:
Better? Maybe a degree to two. Worth it? Absolutely not.
But out of curiosity, for what?
well the hyper 212 is a great budget cpu cooler that works with a lot cpus and the noctcua fans are the best so i just thought it would better if u put them together
https://linustechtips.com/topic/1196542-fans/#findComment-13617353
Until you realize Noctua makes cooler as well and you'd be better off getting one since it would come with Noctua fans and you're not spending money twice for no reason.
https://linustechtips.com/topic/1196542-fans/#findComment-13617355
