Case fan software
What motherboard are you using? There might be a software utility that you can download from the manufacturer website.
https://linustechtips.com/topic/1196470-case-fan-software/#findComment-13616860
I (and many others) prefer SpeedFan, but I think all of the big four motherboard manufacturers include a fan control program in their software package.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/1196470-case-fan-software/#findComment-13616867
Just now, prostrike33 said:
I use a Gigabyte motherboard, would they have one?
Yes, download the App Center from Gigabyte's site, then download and install SIV to it. You can use that to set custom fan curves.
https://linustechtips.com/topic/1196470-case-fan-software/#findComment-13616901
14 hours ago, prostrike33 said:
I have to download App Center to use SIV? I can't just install SIV separately?
Correct. SIV is more of an extension to App Center than it is a standalone program.
https://linustechtips.com/topic/1196470-case-fan-software/#findComment-13619085
