Hey guys, Im gonna be building my first pc. This pc is gonna be mostly for gaming, and making vids for youtube. I have a few questions on a few parts for the pc.
The build
CPU: i5 4670k or i7 4770k
MB: MSI z87-GD65
RAM: G.skill ripjaw 16gb 1600 (4x4gb)
DRIVE: seagate 2tb 7200 ( 2 of this )
SSD: Samsung 840 evo 120gb (for the windows)
CASE: Rosewill BLACKHAWK ULTRA
PS: corsair hx 750w or 850w
CPU COOLING: h100i
OS: Windows 8.1
Few fans for the case nd the big question is the GPU I DONT KNW WHAT TO PICK!
Gigabyte gtx 770 2gb or 4gb
Or
Gigabyte r9 270x 4gb
Any r9 270x or gtx 770 you guys recommend
I would love some feedback on those 3 questions!
https://linustechtips.com/topic/119607-my-first-build/
Agree with the 770. You might also want to consider a 2 x 8Gb set of memory instead of 4 x 4Gb for any future upgrades.
Project Depravity: £850 / ????? (03/12/2015) Case: Phanteks Enthoo Primo SE Red Keyboard: Corsair K95 RGB MX Red Monitors: 3* Asus PG279Q Stand: Ergotech Triple Desk Stand Webcam: Logitch C920
RIP in kill: CPU: Single core Celeron M @1.73GHz RAM: 1GB (512MB x2) DDR2 SO-DIMM Motherboard: Asus MOCA-AR HDD: 160GB SATA2 5400rpm
Current System: CPU: Intel i5-4690K Cooler: Cooler Master Hyper 212 EVO Motherboard: MSI Z97 Gaming 5 RAM: Kingston HyperX Fury 8GB 1866MHz GPU: Gigabyte Windforce 960 4GB SSD: Sandisk Ultra Plus 128GB HDD: WD Caviar Blue 1TB PSU: Corsair CX500M Case: Corsair 200R Windowed MonitorLG 22MP55HQ 22" IPS + HP w19 MouseRoccat Savu Keyboard: Corsair Raptor K30 Mouse Pad: Perixx DX-1000XXL Headset: Kingston HyperX Cloud OS: Windows 10 Pro 64-bit
https://linustechtips.com/topic/119607-my-first-build/#findComment-1594160
Okay, so I'm not sure why you picked the R9 270X as an alternate as it performs...well, terribly in comparison. We'd love to know what your budget is, then we can recommend what kind of GPU you'd be looking at. I would also pick the i5 over the i7 and put some extra cash towards the GPU.
If between the GTX 770 and the R9 270X. I'd definitely get the GTX 770, every time.
CPU: 5930K @ 4.5GHz | GPU: Zotac GTX 980Ti AMP! Extreme edition @ 1503MHz/7400MHz | RAM: 16GB Corsair Dom Plat @ 2667MHz CAS 13 | Motherboard: Asus X99 Sabertooth | Boot Drive: 400GB Intel 750 Series NVMe SSD | PSU: Corsair HX1000i | Monitor: Dell U2713HM 1440p monitor
https://linustechtips.com/topic/119607-my-first-build/#findComment-1594163
Agreed, you'll also get marginally better performance with a dual channel kit as the platform (1150) only officially supports dual channel.
https://linustechtips.com/topic/119607-my-first-build/#findComment-1594165
Which country do you live in?
an AMD card could be a viable choice.
New PC Build - Build Log - http://linustechtips.com/main/topic/276039-project-swift-force/
[spoiler=]
  • Case: Phanteks Enthoo Primo
  • Motherboard: Asus Maximus VII Hero
  • CPU: Intel i7-4790K
  • GPU1: GIGABYTE G1 GAMING GTX 970 4GB
  • GPU2: GIGABYTE G1 GAMING GTX 970 4GB
  • RAM: Corsair Vengeance Pro Red, 16gb (2x8GB) @1600mhz
  • PSU: EVGA SuperNova 850W 80+ Gold
  • CPU Cooler: NZXT Kraken X61
  • HDD: Seagate Barracuda - 2TB 7200RPM
  • SSD: Samsung 840 EVO - 250GB
  • Monitor: Asus PG278Q ROG Swift 27" 144hz G-Sync
  • Headphones: Beyerdynamic DT990 Pro 600 OHM
  • DAC/AMP: Mayflower Objective2 + ODAC Combo
  • Mouse: ROCCAT Kone Pure Optical
  • Keyboard: KBP V60 - Cherry MX Brown
https://linustechtips.com/topic/119607-my-first-build/#findComment-1594193
I would suggest probably looking into getting the
MSI z87-GD45
instead of the MSI z87-GD65
I believe it gives a bit more bang for its buck +  its cheaper ;D
- Last time i looked there was like a $40 difference, thats $40 that you could be spending else where!
<a href="https://hashflare.io/r/311DC12A"><img src="https://cdn.hashflare.eu/banners/en/1280x628_1_eng.png" alt="HashFlare"></a>
https://linustechtips.com/topic/119607-my-first-build/#findComment-1594227
