Hello, I am facing issue with voltages. They seem to suddenly increase while gaming and if I shutdown PC for a while they become normal.
I checked psu with a multimeter while gaming and its in okay range. The cpu runs at 1.6v and ram auto changes its voltage to 1.5v.
12v becomes 13.2v and all other voltages change.
What can the issue be?
Edited by petrenko.d
CPU: Ryzen 7 5700X Undervolted  Motherboard: B550 Aorus Elite V2 Rev1.2 RAM: G.Skill TridentZ Neo 3600Mhz CL16 32gb
GPU: MSI Mech 2X RX6600 8GB Cooler: ProLab Design AI360 LC AIO Storage: WD SN770 500gb + Sn550 1Tb + MX500 1Tb + 1TB HDD
PSU: Antec EAG Pro 750 80+G Case: Deepcool CG580 WH Monitor: Benq Mobiuz EX2510 144Hz
Mouse: G Pro Wireless Keyboard: Corsair K68 RGB Cherry MX Red Speakers: Creative Pebble V2
https://linustechtips.com/topic/1195696-need-help-with-voltages/
Do you have LLC enabled ?
Phone: Pixel 3a (Purple-ish).
Build Log:
No such option in bios
for dram its a little high but for the most part its fine whats weird is the cpu
that is scary high
do you have the latest bios ?
Build Log:
that is scary high
Yes i tried bios from f40 to f50a all exhibited same issue. After around half an hour gaming it shooted up.
I suspect the vrm's may have become dodgy or some sensor is malfunctioning.
One thing they had me do is update the EC Firmware Chip to support latest ryzen cpus and correctly detect dram and it was successful. I think that it may have bugged something off.
that is scary high
1 minute ago, petrenko.d said:
One thing they had me do is update the EC Firmware Chip to support latest ryzen cpus and it was successful. I think that it may have bugged something off.
i think the weirdest thing is the 12v  readings
im trying to think as to why this is happening
Build Log:
2 hours ago, C17H23NO2 said:
Use HWinfo to read the voltages etc, and post a pic.
Same reading on all softwares.
Do you have the latest bios ?
And chipset drivers
Build Log:
I may have managed to solve the issue. I removed the aftermarket cpu cooler, it was exerting a lot of pressure I think and now I am on wraith stealth cooler.
Problem seems to have gone for now.
