No. You can overclock the cheaper one to match the 1845 mhz. But 15 mhz isn't noticeable anyway.
Main PC:
CPU: AMD Ryzen 7 5700X3D | RAM:Corsair LPX 3200 mhz (32GB)
Mobo:ASUS Strix B550-F Wifi | GPU: Gigabyte 9070
Case: Sharkoon Nightshark RGB| Storage: 500 GB 970 EVO Plus 1 TB WD blue 500 GB Samsung HDD
Monitor: iiyama G-Master G2470HSU-B1 165Hz
Powersupply: Cooler Master GX III Gold 750
Main Laptop
CPU: AMD Ryzen 7 4800H | RAM: Team group 16 GB 2666 mhz
GPU: RTX 2060 (MXM swappable)
Monitor: 1080p 120Hz
Storage: 2x 1 TB Samsung 970 EVO NVMe (no raid)
Second Laptop
CPU: Intel Core I5 1235u,  RAM: Crucial 16 GB 3200 mhz
GPU: IrisXe 80 eu
Storage: 512 GB WD Digital SN530 NVMe
Phone:
Xiaomi MI 11
Work Phone:
Samsung Xcover 6pro
https://linustechtips.com/topic/1195527-mhz/#findComment-13609955
2 minutes ago, Winnie Pooh said:
Rtx 2080 super 1830 MHz v rtx 2080 MHz 1845. Would the15 MHz  be forth 30€
Is this a RTX 2080 vs RTX 2080 Super?
If both the same GPU, the extra 15 MHz is NOT worth 30€.
The card will most likely automatically boost / self-overclock pass that.
You can do the MINOR 15 MHz overclock yourself.
You won't even notice the extra 15 MHz in games, it will be maybe 1 ~ 2 FPS difference.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1195527-mhz/#findComment-13609958
