I have a pair of G Pro's I recently got on sale for $40, and they're fine, but the audio cable is way too short. It's got a 3.5mm cable that goes into a splitter for headphones and mic. I tried using a different 3.5mm cable for the unsplit part, but it really screwed up the audio.
Is there a solution to get another 3 feet of cable length without a noticeable reduction in audio quality?
Work Rigs - 2015 15" MBP | 2019 15" MBP | 2021 16" M1 Max MBP | Lenovo ThinkPad T490 |
AMD Ryzen 9 5900X  |  MSI B550 Gaming Plus  |  64GB G.SKILL 3200 CL16 4x8GB |  AMD Reference RX 6800  |  WD Black SN750 1TB NVMe  |  Corsair RM750  |  Corsair H115i RGB Pro XT  |  Corsair 4000D  |  Dell S2721DGF  |
Fun Rig - AMD Ryzen 5 5600X  |  MSI B550 Tomahawk  |  32GB G.SKILL 3600 CL16 4x8GB |  AMD Reference 6800XT  | Creative Sound Blaster Z  |  WD Black SN850 500GB NVMe  |  WD Black SN750 2TB NVMe  |  WD Blue 1TB SATA SSD  |  Corsair RM850x  |  Corsair H100i RGB Pro XT  |  Corsair 4000D  |  LG 27GP850  |
https://linustechtips.com/topic/1194965-cable-extentions-g-pro-headset/
Okay, so, before being split the cable used is 4 pole 3.5mm, the cable you were using is likely only three pole (count the stripes, it will be different). You could either extend each of the split three pole connections or buy a 4 pole extension cable (or just buy a longer cable).
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
perfect, thx!
