Hi guys, so i want to buy new gpu GTX 1660 6GB, i got money and everything but i dont know if it can be placed in my motherboard slot cuz on the right side is sata slot (something like cube) but this graphic card got two fans so i dont know if it can fit.
GTX 950 FTW on a A68HM-e33-v2 msi motherboard - Graphics Cards ...Can i put 1660 on it?
https://linustechtips.com/topic/1194622-help/
what gpu exactly? In general unless the sata block is much taller than the pcie slot you won't have any issues.
Daily Driver: Redmi Book Pro 14 - Core Ultra 7 155H | 32GB/1TB
Primary Desktop: NCase M1 - Ryzen 7 7800X3D/RX 6950XT | 32GB/2TB
Travel PC: Fractal Terra - Ryzen 7 5800X/RTX 3060 Ti | 16GB/1TB
I have too many computers. List here.
https://linustechtips.com/topic/1194622-help/#findComment-13602893
it's hard to tell from the pics but it looks like the sata block isn't higher than the pcie slot and so you should not see any interference
https://linustechtips.com/topic/1194622-help/#findComment-13602922
