5 minutes ago, The_russian said:
You either forgot to connect your CPU cooler fan, or you didn't connect it to the CPU_Fan header. The computer is also not detecting a keyboard. To fix this connect the CPU cooler fan to the CPU_Fan header and connect a keyboard.
I’m not able to find the right header ugh
https://linustechtips.com/topic/1194030-help/#findComment-13598692
