So, I  have acqired a kraken g12 with a corsair h55 to cool my rx 580. That works great, however I cannot seem to be able to control the fans via the silverstone fan hub as they are awfully noisy.
Is there a way to do this? I have a MSI b450 gaming ac itx mobo, so I only have a sys1_fan port which is where the hub is connected. Can I lower the fans rpm's?
https://linustechtips.com/topic/1193805-fan-control/
Can you set a custom curve in the bios?
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1193805-fan-control/#findComment-13596812
I can but it does not seem to matter. Radiator fan goes 100% all the time. Let me explain in more detail.
I have a total of 6 fans, and only 2 fan hubs in motherboard.
Cpu fan goes to cpu fan on mobo.
The other 5 go to the fan hub which is sata powered.
The ones that are in the hub are the aio pump, the vrm fan in the g12, the radiator fan, and 2 140mm phanteks fans. I would like to be able to adjust any of them, they however are not pwm, but if I could lower the voltage via sys fan that would work too, since they would go slower.
https://linustechtips.com/topic/1193805-fan-control/#findComment-13597041
