I have the Corsair H50 on my i5 2500k OC'd to 4.3ghz on auto voltage. My temps seem to jump alot on core 2 as read by Coretemp 1.0. It jumps anywhere from 35-45 at idle... Is it possible that I may have over tightened my h50 on the board? The other 3 cores stay stable within 2 or 3 degrees at idle. Temps arent way out of wack or anything, during prime95 sitting at about 60 after about 5 min of running, so im really not all that worried on temps, but I am at the same time.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/119342-cpu-temps-h50/
I will be re-seating it soon when I get my Corsair C70 case in the mail in a few days. Also, I noticed my temps jumped a little bit when I flipped it. I had the hose output at the bottom for almost 3 years, then I decided to rearrange some things in my case and flipped it upside down as ive read it doesnt matter the orientation since its a closed loop. It was after this that I had started seeing the temp differentials.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/119342-cpu-temps-h50/#findComment-1590734
