Ethernet Wifi Speed
Go to solution Solved by Guest,
1 minute ago, PorkishPig said:
As other suggested, make sure that the issue is exclusive to your computer before you continue troubleshooting. If the issue is exclusive, make sure that the USB extension cable that you're using is USB 3.0.
It is usb 2.0 thank you for the answer
I am useing a ethernet cord plugged up to a ethernet to usb adapter and that is plugged up to the usb extension cable (ethernet cable was not long enough) which then plugs into my computer. My wifi plan is 300mb but when I run a speed test on my computer it is only about 190mb. This does not make sense because i am useing ethernet. It is not my ethernet cable because it is cat6. Why is this?
https://linustechtips.com/topic/1193361-ethernet-wifi-speed/
Could be the adapter, what is the adapter rated for?
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
https://linustechtips.com/topic/1193361-ethernet-wifi-speed/#findComment-13593414
What is the model of the USB to ethernet adapter?
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
https://linustechtips.com/topic/1193361-ethernet-wifi-speed/#findComment-13593417
4 minutes ago, Electronics Wizardy said:
What speed do other systems get on the network?
Can you test the speed with iperf to anouther system on the network?
when you try it on another device it is 300mb at first but then if you check again later after you have started doing things it is the same as my computer
https://linustechtips.com/topic/1193361-ethernet-wifi-speed/#findComment-13593428
okay so i finnally found it and it is rated up to 1gb link below
wonder if it has something to do with usb extension cable
https://www.amazon.com/dp/B00MYTSN18?ref=ppx_pop_mob_ap_share
https://linustechtips.com/topic/1193361-ethernet-wifi-speed/#findComment-13593485
Desktop
Homelab
https://linustechtips.com/topic/1193361-ethernet-wifi-speed/#findComment-13593505
https://linustechtips.com/topic/1193361-ethernet-wifi-speed/#findComment-13593522
@turtlecraft
While USB 2.0 is rated to go up to 480 Mbps, which you should be able to achieve given that it is the slowest point in your wired connection (hopefully, the ethernet is gigabit), there is bound to be signal degradation with the amount of links in that single connection.
If the USB interface is being shared with multiple other devices, this can also slow down the overall speed of the adapter. And Cat5e ethernet runs greater than 100m cannot guarantee gigabit link speeds.
https://linustechtips.com/topic/1193361-ethernet-wifi-speed/#findComment-13593914
