I need a bit of help here. I have an i5 3570k and a Powercolor 7970 (got a good price for it), with an antec earthwatts 500w PSU. Lately I've had some artifacting issues, even when just web browsing or watching a video. I didn't have any issues in the past when I had my Athlon X3, and this is only recently, like the past month or so. What do I do? I'm kinda worried. I already re-installed drivers, but no dice. Anybody have a clue on what's happening with my 7970?
Video Game, Anime and Tech Fan!
 Current Build - CPU: Intel Xeon x5660 @ 4.2GHZ / MOBO: ASUS P6T / COOLER: Cooler Master Hyper 212 + / GPU: Radeon HD 7970 / RAM 8GB Corsair XMS3 / STORAGE: OCZ Agility 3 60gb, WD Blue 1TB / CASE: Bitfenix Shinobi PSU / Antec Earthwatts 500w / DISPLAY: Asus 23 inch @1080p, Dell 19 inch @ 1440x900, Seiki SE42UM @ 4K
Mobile Devices: HP Chromebook 14, 3DS XL, Vita, Samsung Note 4, LG G Pad 8.3, Chuwi Hi8, NEX-3N
https://linustechtips.com/topic/119326-7970-artifacting-issues/
I had the same thing with my 7970 lightning at stock on the desktop. Had to rma it :(.
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/119326-7970-artifacting-issues/#findComment-1590838
:o
https://linustechtips.com/topic/119326-7970-artifacting-issues/#findComment-1590996
Monitor your HD 7970.
- How are the temperatures?
- Is the GPU fan operating properly (is it spinning)?
What version drivers are you using?
Did you happen to get your Powercolor Radeon HD 7970 used?
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/119326-7970-artifacting-issues/#findComment-1593509
Could be your PSU?
My PC specs; Processor: Intel i5 2500K @4.6GHz, Graphics card: Sapphire AMD R9 Nano 4GB DD Overclocked @1050MHz Core and 550 MHz Memory. Hard Drives: 500GB Seagate Barracuda 7200 RPM, 2TB Western Digital Green Drive, Motherboard: Asus P8Z77-V , Power Supply: OCZ ZS series 750W 80+ Bronze certified, Case: NZXT S340, Memory: Corsair Vengance series Ram, Dual Channel kit @ 1866 Mhz, 10-11-10-30 Timings, 4x4 GB DIMMs. Cooler: CoolerMaster Seidon 240V
https://linustechtips.com/topic/119326-7970-artifacting-issues/#findComment-1594414
