Budget (including currency): The budget i would like to do is around 800(give or take 100) USD only because i will still have to buy a monitor, mouse and keyboard.
Country: United States
Games, programs or workloads that it will be used for: I would like a PC that would be able to run battle royal games like COD Warzone, Apex and Fortnite. I also would like to be able to play some other titles like League of Legends, GTA V and some other RPG games. I also want to get into some video editing as well down the line.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I really like the AMD Ryzen 5 3600 CPU with the reviews but i am open to other suggestions. I keep seeing reviewers saying having an open mesh case for your system is needed to avoid over heating but i also see a lot of other people do fine without the mesh front. Prefer a white set up, but black is fine as well.If i could get some monitor, keyboard and mouse suggestions that would be great as well.
https://linustechtips.com/topic/1193003-first-pc-build/
How much do you want to spend for the keyboard, mouse, and moniter?
Quote me or mention me at @Shrekpad so I get notified
pc specs:
CPU:
Intel i7 8700K MOBO: ROG Strix Z390-E Gaming RAM: 16GB (2x8) DDR4 G Skill TridentZ 3000 MHz GPU: Gigabyte GeForce RTX 2080 SUPER GAMING OC CASE: Phanteks Enthoo Evolv STORAGE: Sabrent Rocket Q 1TB M.2 NVME SSD,
T-Force Delta RGB 250GB SSD, 4TB Seagate Barracuda HDD PSU: 750 Watt EVGA SuperNova G3 MONITERDell S2716DGR 1440p 144hz G-Sync, BenQ PD2700U 4K 60hz CPU COOLER: Corsair H115i RGB Platinum OS: Windows 10
https://linustechtips.com/topic/1193003-first-pc-build/#findComment-13590898
Total for all maybe around 200 to 25 if possible.
https://linustechtips.com/topic/1193003-first-pc-build/#findComment-13590905
This is a good 1080p moniter:
https://pcpartpicker.com/product/pXMTwP/msi-optix-g241-238-1920x1080-144-hz-monitor-optix-g241
And keyboard and mouse is really personal preference.
pc specs:
CPU:
https://linustechtips.com/topic/1193003-first-pc-build/#findComment-13590911
11 hours ago, Demonix_Hermit said:
Thanks! Looks like a good build
https://linustechtips.com/topic/1193003-first-pc-build/#findComment-13592685
