Current Rig:
ASUS Z390-E ROG Strix Gaming Intel LGA 1151 ATX Motherboard
Intel Core i9-9900K (overclocked to 5 GHz running 1.28V.)
EVGA GeForce RTX 2080 Ti
Corsair Hydro H115i Platinum 280mm
3 x 120mm corsair intake fans on front of computer
I am running Folding@Home continuously and I am having trouble keeping my temps down. Currently they sit pretty regularly in the high 70's c, hitting low 80's every once in a while. What cooling solution do I need to bring that down to where my computer is safe to run continuously? All of my corsair fans and my cooler pump are set to their "extreme" pre-settings, since I don't care very much about fan noise right now.
Temperature was not as much of an issue when I had the GTX 960 that I upgraded from.
https://linustechtips.com/topic/1192894-need-cooling-assistance/
9900k is just a hot running chip. You could run a lower overclock on it or just run the GPU and nothing else since the GPU smokes it in speed anyways
Desktop benching:
5 minutes ago, Turbo.SG said:
Go for a Noctua NH-D15 or custom water cooling with more radiators.
Jesus, that's a big shift between options.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
70-80C during high load isn't a problem.
What temps do you have on your GPU ?
Your 2080ti is obviously giving off a lot of heat inside your case which increased the air temps going through your AIO radiator.
Can you mount the radiator in the front for intake ? That would most likely give you better CPU temps.
This would of course affect your GPU temps but maybe not as much (you need to test and see).
CPU: i9 9900K   Cooler: NH-D15   RAM: Kingston Fury 4 x 8GB 3600MHz CL17   Mobo: ASUS ROG Strix Z390-F   GPU: ASUS 3080 TUF   Case: Be Quiet! 500DX   PSU: Corsair HX850i   Storage: 250GB Samsung 970 EVO NVMe (OS), 500GB Samsung 970 EVO NVMe (Games), 2TB Crucial BX500 SSD (Storage)   Monitor: Samsung Odyssey Neo G9.
These are 24/7 temperatures due to the continuous 100% load from F@H.
I actually never knew this, since it has never mattered before and I have never overclocked my GPU. A quick google search suggests MSI Afterburner as the software of choice for overclocking and temp management of GPU, so I will go there.
I will attempt, but I believe I remember trying before and it not quite fitting correctly. I also avoided this due to a few forums/videos saying that exhausting the air over the radiator is better in the long run.
For the time being, I have turned the CPU folder off. I don't know if I am ready to invest in full custom water cooling yet, either with time or money. If that ends up being the necessity then I will do so when I am able.
55 minutes ago, Turbo.SG said:
Noctua NH-D15
Are you kidding? He's on a liquid cooler now and he wants more cooling performance and you're giving him an air cooler as an option?????🤨
  • My system specs
  • View 91 Tempered Glass RGB Edition, No PSU, XL-ATX, Black, Full Tower Case
  • ROG MAXIMUS XI EXTREME, Intel Z390 Chipset, LGA 1151, HDMI, E-ATX Motherboard
  • Core™ i9-9900K 8-Core 3.6 - 5.0GHz Turbo, LGA 1151, 95W TDP, Processor
  • GeForce RTX™ 2080 Ti OC ROG-STRIX-RTX2080TI-O11G-GAMING, 1350 - 1665MHz, 11GB GDDR6, Graphics Card
  • ROG RYUJIN 360, 360mm Radiator, Liquid Cooling System
  • 32GB Kit (2 x 16GB) Trident Z DDR4 3200MHz, CL14, Silver-Red DIMM Memory
  • AX1600i Digital, 80 PLUS Titanium 1600W, Fanless Mode, Fully Modular, ATX Power Supply
  • Formula 7, 4g, 8.3 (W/m-K), Nano Diamond, Thermal Compound
  • On AIO cooler 6 x NF-F12 IPPC 3000 PWM 120x120x25mm 4Pin Fibre-glass SSO2 Heptaperf Retail
  • 6 x NF-A14 IPPC-3000 PWM 140mm, 3000 RPM, 158.5 CFM, 41.3 dBA, Cooling Fan
  • 1TB 970 PRO 2280, 3500 / 2700 MB/s, V-NAND 2-bit MLC, PCIe 3.0 x4 NVMe, M.2 SSD
  • Windows 10 Pro 64-bit
  • Beyerdynamic MMX 300 (2nd Generation) Premium Gaming Headset
  • ROG PG279Q
  • Corsair K95 Platinum XT
  • ROG Sica
Not really. They didn't even test the NH-D15S in this video... which is better than what was used.
I take it back. I can't believe from pure cooling performance air cooling was better than liquid. Until now I always thought liquid is better for lower temps. I mean it seems obvious from pure logic. Thank for sharing the video!
  • My system specs
  • ROG PG279Q
  • ROG Sica
I wish they would have tested a 360mm cooler
  • My system specs
  • ROG PG279Q
  • ROG Sica
The Gamers Nexus video is much more comprehensive.
If you go full custom loop you can get better numbers because you're usually using more than one radiator. I also don't trust AIOs anymore because I had one that died on me after about 8 months of use. I'm on an NH-D15S Chromax and I'm in love. Quieter and better temps.
2 minutes ago, Turbo.SG said:
full custom loop
I knew you could better temps with a custom loop but, I didn't know an air cooler could be better than an AIO.  Is there any way to improve cooling performance without changing my AIO? Are there any better fans that you know of than my current fans? I might go Z490 with 10900k
  • My system specs
  • ROG PG279Q
  • ROG Sica
Those temperatures aren't a problem.  105C is the spec where it's safe to run forever.
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
If you're going to keep the AIO I would get Noctua fans although best case scenario would be a Noctua or Be Quiet! air cooler.
I already have Noctua fans. Check my signature for my system specs.
  • My system specs
  • ROG PG279Q
  • ROG Sica
