3 hours ago, Arcuto said:
It’s rmx 850 Corsair I only need one for cpu and one pcie cable for the gpu right that’s pretty much all I need am I right?
What GPU do you have ?
And yes you need an 8pin eps for the cpu and that's pretty much it
BUT PLEASE MAKE SURE IT'S eps not pcie
Those are two different things
But for pcie cable you might need 2 so what's your GPU ?
Phone: Pixel 3a (Purple-ish).
Build Log:
