G'day Guys how are we?
I have EVGA SuperNOVA 650 G1+ & looking to get a CableMod kit but not sure which of the below to get.
I've checked the compatibility chart and my PSU is on it.
Are there any compatibly differences between the below or will either work with my PSU?
CableMod PRO ModMesh C-Series AXi, HXi & RM Cable Kit White (CM-PCSI-FKIT-NKW-R)
or
CableMod PRO ModMesh C-Series RMi & RMx Cable Kit White (CM-PCSR-FKIT-NKW-R)
  Thank you
CPU: AMD 5800X3D / Cooler: Noctua NH-U9S / Motherboard: MSI MPG B550 / GPU: EVGA GTX1070 SC / RAM 64GB G.Skill TridentZ RGB / SSD: WD Black NVME / HDD 1: ADATA XPG SX9200 Pro / HDD 2: Lexus NS100 / PSU: CORSAIR RM850 / Case: Corsair 5000D
https://linustechtips.com/topic/1192460-cablemod-pro/
Neither of the 2 you have listed will work since they are for Corsair PSU's not EVGA.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1192460-cablemod-pro/#findComment-13586983
or
  Thank you
You need an E-Series kit.
https://linustechtips.com/topic/1192460-cablemod-pro/#findComment-13586993
Oh yep true thank you
https://linustechtips.com/topic/1192460-cablemod-pro/#findComment-13587007
