What do you mean by damaging? They dont have Threads, if you mean that.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/1192418-help/#findComment-13586693
You have to use silicon washer on the screw head side.
https://linustechtips.com/topic/1192418-help/#findComment-13586719
6 minutes ago, BlueScope819 said:
Please please please do not push the screws into the rad, you are going to break it. You may be using the wrong screws, perhaps you have slimmer fans than intended. You can either use washers to make up the difference, or you can use smaller screws and not go through the top holes in the fan.
Ya. He shouldnt listen to the Perosn who said its fine. Looks like who ever said that, want him to damage it.
https://linustechtips.com/topic/1192418-help/#findComment-13586745
