Water cooling case
Go to solution Solved by Tartempion,
I decided to go with th 750D instead.
Hi, I am looking for a new case to put water cooling hardware in. I currently plan on getting a 360mm and a 240mm radiators. I have stumbled upon two choices:
1: NZXT H440
  • ST30 360mm radiator in the top
  • XT45 240mm radiator in the front
2. Corsair 750D
  • XT45 360mm radiator in the top
I am really liking the looks of the H440. I guess if I go with eh 750D, I have enough room for everything.
For the H440 owners, can I put the top radiator ports on the left like in this image :
Thank you
https://linustechtips.com/topic/119241-water-cooling-case/
I would flip the rad up top around and then run the tube that goes from that to the CPU behind the mobo tray.  You could also run the tube from the 2nd GPU straight down through that hole
i5 4670k| Asrock H81M-ITX| EVGA Nex 650g| WD Black 500Gb| H100 with SP120s| ASUS Matrix 7970 Platinum (just sold)| Patriot Venom 1600Mhz 8Gb| Bitfenix Prodigy. Build log in progress
Build Log here: http://linustechtips.com/main/topic/119926-yin-yang-prodigy-update-2-26-14/
https://linustechtips.com/topic/119241-water-cooling-case/#findComment-1589542
