So i finished my first build with:
3700X
2070 Super
B450 Tomahawk Max
16GB 3600 DDR4
Cooler Master Masterliquid 240
Seasonic Focus+ 750W Modular PSU
The issue is I randomly get reboots when I'm not under any CPU or GPU load. I have not OCd anything other than getting my RAM to the 3600. Installed all drivers, updated BIOS. The screen just goes dark with no information shown, I only get a CPU debug LED, then upon booting I get a VGA then Boot debug LED.
3700X
2070 Super
B450 Tomahawk Max
16GB 3600 DDR4
Perhaps lower the memory frequency to 3200mt/s and see if that helps stabilize the system.
Just Curious, i have an identical build. I just finished my build and i have not been able to boot at all. Everything turns on but i get a boot debug Led and no video out. Im currently running 32 gigs of 3600 G Skill. Does the board need an update in order to support 3600 Ram?
Thanks!
Thanks!
If it has never booted before then the RAM would be at 2133Mhz until you set it to 3600Mhz.
Try only one stick of ram/
It's not a race to the bottom.
Im guessing the ram is the issue i tried booting with single stick same result. tomorrow im going to go to my local pc parts store and see if i can try  2133 Mhz to get it into bios. Once i do this i can change the settings there correct and then continue with the 3600 Mhz?
