Most power supplies support both 110v and 220v, but I would double check the specs to make sure it does. If it does support both, then you can either get an adapter or buy a different power cable. The power cable for power supplies is removable/replaceable. Keep in mind this all assumes that the unit supports multiply voltages, so if it doesn't then you will have to return it.
https://linustechtips.com/topic/1192005-psu-wall-plug/#findComment-13583573
