PCI-E v2 16x but running at 1x
XaiGRS
im having fps drops in games and found this in hwinfo, what does this mean and what can i do?
Main PC: ROG Zephyrus G14 2020
CPU : AMD Ryzen 7 4800HS |
RAM : 16Gb DDR4 |
GPU : Nvidia GTX 1660Ti Max Q |
Storage : 512Gb NVme SSD |
Secondary PC:
CPU Xeon E5 2620 v3 |
Mobo : Jingsha X99 D4 |
RAM : 16Gb DDR4 |
Cooler : Deepcool Ice Edge Mini FS V2 |
GPU : Nvidia GTX750Ti |
Storage : Samsung 860 EVO 250gb (OS) |
PSU : Super Flower SF-500R12N |
Case : Cube Gaming Fernos |
Peripherals:
Monitor : AOC 24G2 |
Keyboard : Digital Alliance Meca Fighter Ice - Akko CS Vintage White |
Mouse : HyperX Pulsefire Haste |
Headphones : Phillips SHP9500 |
Mic : Taffware BM800 |
Mic Arm : Some cheap bogstandard arm |
You're running a GTX 660, that card is old enough that it's not going to need much bandwidth anyway.  However, I doubt it's staying in 1x mode when you're in a game.  That's just a power saving method when you're on the desktop.  Try checking HWInfo while in game.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
First thing:
- What game are you playing?
- Which slot is your graphic card located? The bottom PCIe slot or the top PCIe slot of your motherboard?
- Have you update your GPU driver and motherboard chipset driver?
Since you mentioned that your graphic card is from an Alienware machine, I'm afraid that there might be compatibility issues if you plug it to normal desktop. Maybe you can get GPU-Z and run PCI-Express render test to see if the PCIe automatically switch to PCIe 3.0 x16 or PCIe 2.0 x16.
I have ASD (Autism Spectrum Disorder). More info: https://en.wikipedia.org/wiki/Autism_spectrum
I apologies if my comments or post offends you in any way, or if my rage got a little too far. I'll try my best to make my post as non-offensive as much as possible.
nope that is infact the gpu running on 1x. just reseated it and cleaned the slot and walaa hwinfo says its x 16 now. no more frame drops/
43 minutes ago, Chiyawa said:
First thing:
csgo and r6s
top slot
latest game ready driver
RAM : 16Gb DDR4 |
Secondary PC:
RAM : 16Gb DDR4 |
Peripherals:
41 minutes ago, Chiyawa said:
First thing:
unrelated but im not aware that there are compatibility issues for oem cards. do you have any examples?
RAM : 16Gb DDR4 |
Secondary PC:
RAM : 16Gb DDR4 |
Peripherals:
Well, I remember that some OEM card may have issue as it would not want to boot if its plug in to other system. Very rare case.
