Hello guys, I don't understand much about pc's, but few weeks ago i built a pc, my specs are GTX 1650 4gb, 8gb ram, h310m pro, i3 9100f and matrix 800w psu(i posted a picture of it)
I have a problem after i use my pc for some time(7-9 hours),at some point the screen freezes and after few seconds turns black,then turns on and that repeats again after 2-3min...And i have to shut down my pc, and take a 20-30 min break.. I think its my psu but i don't really know... Also once my graphic card *crashed* or whatever and started using 100% of itself and the whole pc was lagging, I had to reinstall my gpu drivers and restart the pc for it to start working again.. i really need help the pc is really new and i need to fix it before it ruins other components(if its my psu), also i dont have any coolers, should i buy coolers instantly??
https://linustechtips.com/topic/1191331-problem-with-pc/
try and look at the temps for gpu and cpu if they are above 70*C when doing nothing then you've got a problem there. Are all your cables plugged in all the way?
If you judge a fish based on its ability to climb trees it will go its whole life thinking its a failure.
https://linustechtips.com/topic/1191331-problem-with-pc/#findComment-13579058
1 minute ago, Rogerzz said:
I would replace the PSU regardless it has no reviews and has no ratings. It costs $20 so........
oh... oh no thats pretty sketchy
https://linustechtips.com/topic/1191331-problem-with-pc/#findComment-13579072
yea i thought so too, it came together with the pc case and it was 50$ all together so I took it, I saw on internet that i wouldnt need more than 500w and i thought 800w are more than enough, I didnt know how important it is but ill change it and put some fans in..
https://linustechtips.com/topic/1191331-problem-with-pc/#findComment-13579089
Just now, Rogerzz said:
The PSU you have probably only actually outputs 200W-250W at most thats why it crashes a lot.
PSU 500W Sharkoon WPM500 80 Plus Bronze Real Power Modular, Silent, 14cm Fan
 is this ok because i live in a small country and we dont have that much stuff here...
https://linustechtips.com/topic/1191331-problem-with-pc/#findComment-13579102
https://ddstore.mk/products/Cooler+Master+MWE+650W%2C+230V%2C+80Plus+Bronze/pid/921091
Get two 120mm fans stick one at the back of the case and one at the front, any fans are better than none.
Thanks again man, i will get those as fast as I can.
https://linustechtips.com/topic/1191331-problem-with-pc/#findComment-13579163
