Hard Drive Vibration Buzzing
Go to solution Solved by Kilrah,
Just loose mounting.
Hi everyone, I'm looking for some help here. Just now I woke my computer from sleep and noticed a buzzing noise. I restarted and it was still there so I popped off the side panel and took the video below. The sound is definitely caused by hard drive vibrations because it stops or gets quiter when I put my finger on it. I'm wondering if this is a sign that something is wrong and how I would go about fixing it if it is. Also the hard drive in question is the Seagate Barracuda 7200rpm 2tb which I've had vibration problems with in the past.
*You may need to turn your volume up to hear the noise, my microphone isn't that good.
Mesh Devil
AMD Ryzen 3600 | MSI b450 Tomohawk MAX G.Skill Ripjaws 2x8 3200mhz
Powercolor Red Devil RX 5700 xt
Samsung 860 EVO 500 GB | Seagate Barracuda 2 TB
Corsair RM650x
Fractal Design Meshify C Tempered Glass
https://linustechtips.com/topic/1191317-hard-drive-vibration-buzzing/
Well, getting a cannot play video error (no supported format/mime type)
Either way, might want to look into backing up whatever is there and moving to a newer HDD or and SSD
Alienware Area 51m 2019:  RTX 2060 | i7-9700 | 32GB Corsair Vengeance (2x16GB) 2666 | 1TB 970 EVO | 240GB Corsair Force MP510.
https://folding.extremeoverclocking.com/user_summary.php?s=&u=812790
https://pcpartpicker.com/user/NZKshatriya/saved/
BACKUP SYSTEM:  ASUS Prime X470 PRO | Ryzen 5 1600 | G.skill FORTIS 16GB(2x8GB) 2400 | SanDisk SDSSDA 120GB | EVGA SuperNOVA GA 850 | HAF-XB-EVO
F@H
GPD Win 2
I remounted it and tightened the cage. No sound as of booting back up, so I guess this is solved. Thanks!
Mesh Devil
Corsair RM650x
