Hello I bought an NZXT for myself and now in chosing which liquid cooler i should choose.
If i go with the best bang for the buck i would go with the Arctic Freezer 280 II because it is just € 80.
But then i have the problem that this radiator incl. Fan will be to thick for the case to be installed in.
Now to my question. If i would install the Fan in the Front part of the case.
Would the space (3cm) fans allow enough space for a good air intake?
I hope someone can help me and sorry for the Metric number
https://linustechtips.com/topic/1191311-front-installed-liquid-cooler/
You could always set them up in a pull configuration so that the fans are mounted on the "back" of the rad and are pulling air through it. Makes it a bit easier to clean as well as dust isn't trapped between the rad and fans if they were mounted on the "front" of the rad and pushing air through it.
"Rawr XD"
