Hi so anyway, when I am on GTA or some other game similar to that, my CPU goes to 93 degrees Celsius and stays there. I use the stock AMD cooler
Specs:
MSI B450 Tomawhawk
Corsair LPX 8x2 3600 mhz
Ryzen 5 2600x
Sapphire Pulse RX 5700xt
Corsair CXM 650w
Inland Premium 1tb NVME SSD
I'm probably missing something
https://linustechtips.com/topic/1190538-overheating-cpu/
Just now, Starelementpoke said:
Do you actually experience any slowdowns or are you just noticing the CPU reaching those temps?
After I ran a user benchmark it said my CPU was performing in the 20 percentile, which wasn't great and in GTA I was getting only 60 fps which I was expecting it to be better, but I may be wrong
https://linustechtips.com/topic/1190538-overheating-cpu/#findComment-13572826
Do you have GTA capped to 60 FPS in settings?
https://linustechtips.com/topic/1190538-overheating-cpu/#findComment-13572828
1 minute ago, ferariforests said:
No its capped at 144
Just reseat the heatsink without replacing the thermal paste then. It's not ideal but shouldn't cause any series problems and would let you figure out whether or not it is just a seating problem or not.
https://linustechtips.com/topic/1190538-overheating-cpu/#findComment-13572843
Then you go from there. Only thing I can think of other than that is that it's a busted CPU or sensor maybe. Most likely scenario is that it's just a seating problem.
What happens if I bend the pins when I take out the cooler, do you think I will still have warranty if I built this in February?
https://linustechtips.com/topic/1190538-overheating-cpu/#findComment-13572860
I dunno, it's your warranty. Just be as careful as you were building it as taking it off.
https://linustechtips.com/topic/1190538-overheating-cpu/#findComment-13572865
What are your idle temperatures? Does the fan also get really loud as the temperatures go up? What software are you using to read the temps? Is there at least decent airflow inside your case?
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1190538-overheating-cpu/#findComment-13572872
Just now, Mateyyy said:
What are you idle temperatures? Does the fan also get really loud as the temperatures go up? What software are you using to read the temps? Is there at least decent airflow inside your case?
The fan is always loud, im gonna check idle temps rn, and I'm using afterburner for ingame temps, I have two deepcool rf120 fans, one intake, one exhaust
https://linustechtips.com/topic/1190538-overheating-cpu/#findComment-13572887
Use Ryzen Master or HWiNFO to check temperatures for Ryzen, as most other apps will not provide accurate readings.
https://linustechtips.com/topic/1190538-overheating-cpu/#findComment-13572892
I have 3 tabs open and I'm at 71 Celsius
Rechecks the temperatures with either Ryzen Master or HWiNFO.
If they're still this high particularly at idle, remount your cooler.
https://linustechtips.com/topic/1190538-overheating-cpu/#findComment-13572920
This is my userbenchmark https://www.userbenchmark.com/UserRun/27718693, my GPU is in the 1st percentile, how do I fix that?
https://linustechtips.com/topic/1190538-overheating-cpu/#findComment-13573150
This is my user benchmark https://www.userbenchmark.com/UserRun/27718693, my GPU is in the 1st percentile, how do I fix that?
https://linustechtips.com/topic/1190538-overheating-cpu/#findComment-13573152
Userbenchmark is trash. Use proper benchmarking tools like Cinebench and 3DMark.
https://linustechtips.com/topic/1190538-overheating-cpu/#findComment-13573298
