14 minutes ago, Goku1814 said:
What would be the best budget z370 motherboard?
DO not get 8th gen intel now. ryzen is no-brainer right now.
something like this would work:
PCPartPicker Part List
Type Item Price
CPU AMD Ryzen 5 3600 3.6 GHz 6-Core Processor $172.39 @ Newegg
Motherboard MSI B450 TOMAHAWK MAX ATX AM4 Motherboard $114.99 @ Best Buy
Memory G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 Memory $83.99 @ Newegg
  Prices include shipping, taxes, rebates, and discounts
  Total $371.37
  Generated by PCPartPicker 2020-05-06 04:06 EDT-0400
that cpu is much ebtter than i5 8400
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
@SavageNeo does have a point.
If you NEED to get a new motherboard for a NEW CPU, might as well put Ryzen 3600 (or higher) in your consideration -- just as a side-by-side comparison even.
I would not get a i5-8400 either.
It's a 2.8 GHz base clock, and boosts UP TO 4.0 GHz.
2.8 GHz all-core base frequency is on the low side.
You should consider a i5-8600(K / non-K) or i5-9600(K / KF / non-K) instead.
From what I can see, the P-states / boost tables are as follows for the i5-9600.
Keep in mind, these are UP TO numbers...
  • 1 Core active (remaining 5 cores idle) -- up to 4.6 GHz
  • 2 Cores active -- up to 4.5 GHz
  • 3 Cores active -- up to 4.5 GHz
  • 4 Cores active -- up to 4.4 GHz
  • 5 Cores active -- up to 4.4 GHz
  • 6 Cores all active -- up to 4.3 GHz
i5-9600K / 9600KF has a base frequency of 3.7 GHz, and boosts up to 4.6 GHz as well.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
5 hours ago, Goku1814 said:
I mostly just wanna play borderlands 3 at 1080p and doom enternal. Does the graphics card have to be AMD or will a Nvidia one work?
Graphics card does not matter, either AMD or nVidia will work fine.
Doom Eternal (also Doom 2016) is more optimized with AMD GPUs, though.
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
