Prebuilt Power Supply and case reuse
Solved by Guest,
2 hours ago, Tehqzy said:Also as the topic title mentions, could i use the prebuilt case as well? Im asking this because i have no screws that came with it obviously as its like 10 years old and im worried they are important
It's a standard ATX. 90% of the time the stand offs should line up. Worst case, you get a new motherboard and they don't. Then what do you do? You get a new case, which is where you would be regardless.
1 hour ago, Tehqzy said:Ok thanks
He doesn't know what he's talking about.
