4 minutes ago, nischayvm said:
Please checkout the video before reading this
No thanks, you could describe the problem, along with your specs which is a lot more handy.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1189512-help/#findComment-13564692
Looks like someone went and started tweaking things without noting what it was they were tweaking.
There is always the option of of doing a refresh on the Windows install (backup data first, just in case)
Alienware Area 51m 2019:  RTX 2060 | i7-9700 | 32GB Corsair Vengeance (2x16GB) 2666 | 1TB 970 EVO | 240GB Corsair Force MP510.
https://folding.extremeoverclocking.com/user_summary.php?s=&u=812790
https://pcpartpicker.com/user/NZKshatriya/saved/
BACKUP SYSTEM:  ASUS Prime X470 PRO | Ryzen 5 1600 | G.skill FORTIS 16GB(2x8GB) 2400 | SanDisk SDSSDA 120GB | EVGA SuperNOVA GA 850 | HAF-XB-EVO
https://linustechtips.com/topic/1189512-help/#findComment-13564735
Can you tell me what else is not working. From the video I only see that the (Right click -> New) button isn't working. Also did you use some kind of tutorial or did you just start click on random stuff? If you have a Windows back up image you can try that too. (Would be really easy).
You mentioned in one of the replies that your English is poor. Do you happen by chance to speak Russian? Ты случайно не говоришь на русском?
"Should a machine not function upon striking the panel marked "on" this is an omen of great ill. The reasons ascribed may be as follows. Firstly, the function of inadequate preparation on the part of the operator. Secondly, the action of the machine whose spirit may refuse the binding of the operator. Thirdly, the malintent of some third party upon the operator or machine. The operator must repeat the ritual from the beginning re-purifying himself, enscribing the runes, intoning the incantations, and striking the panel marked 'on'. An accompanying oath may be made. Should this procedure fail, the operator must recourse to consulting the instruction manual." -Runic Spaceflight - An Introduction: Naval Flight Manual W110E
https://linustechtips.com/topic/1189512-help/#findComment-13580286
