display No DISPLAY from GPU! Help!
Solved by kaneto,
Just now, -rascal- said:
When you took the CMOS battery out, did you also unplug the PC from the wall socket?
You NEED to do that too.
Double check to make sure the GTX 1050 is properly installed into the PCI-E X16.
If you can, upload a picture of the inside of your PC here, with the graphics card installed in the computer.
We can try to spot for any physical issues...
I fixed it! Thank god. I did remove everything and yes the GTX 1050 is properly installed. I just had to remove the dvi-d and put the hdmi and i spam clicked delete and suddenly it popped up. Thank you everyone who helped me
