10 minutes ago, Yasir Mehmood said:
distribute wifi between 1000 people in 1KM of range
This is not a trivial setup. Wi-fi straight up doesn't have 1km range (limited by transmit power of client devices) or bandwidth (each additional device is another chance for transmit collision, especially in an area 1km in radius (hidden nodes)). I highly doubt there's a single antenna solution.
We're talking dozens of access points, at least, I'd wager.
Main System (Byarlant): Ryzen 9 5950X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 990 EVO Plus 4TB | Corsair RM750X | StarTech 4× USB 3.0 Card | Realtek RTL8127 10G NIC | Hyte Y60 Case | Dell U3415W Monitor | Keychron K12 Blue (RGB backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K4 Brown (white backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 128GB Micron DDR4 ECC 3200MT/s | 2× Samsung PM963a 960GB SSD / 4× WD 10TB / 4× Seagate 14TB Exos / 4× Micron MX500 2TB / 8× WD 12TB (custom external SAS enclosure) | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (AQC107) 10G NIC | LG WH14NS40 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ══╦═ Pro XG 8 ══╦═ Flex 2.5-8 ══╦═ Doven Wolf
                      La Vie en Rose (DNS) ═╬═ Narrative  ╠═ Veda-NAS     ╠═ La Vie en Rose (vmbr)
                                Veda (DNS) ─┘             ╠═ Veda (vmbr)  ├─ Ptolemy (vmbr)
╔═════════════════════════════════════════════════════════╩═ Ptolemy-NAS  ├─ Veda (Mgmt)
║   ┌ Closet ┐      ┌───────── Bedroom ─────────┐                         └─ Veda (IPMI)
╚═══ Flex XG ══╦╤═══ Flex XG ══╤╦═ Byarlant
       (PoE)   ║│              │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐  │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘  └── Work Laptop
     Bedroom ══╝│        ┌─────── Media Center ────────────────────────────┐
     Jack #2    └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
2 hours ago, Yasir Mehmood said:
I want to setup wifi network i have 2 connection of wifi 250MB and 500MB and distribute wifi between 1000 people in 1KM of range.
What type of wifi outdoor antenna i should use?
And how to setup this network?
You’re talking WISP setup here, which by no means is going to be simple or cheap. While I admire your DIY approach, have you tried contacting a local firm to help you plan this out properly? Will you be providing technical support yourself for this setup?
Do you represent a small business? What is the purpose of this project? And when you say “i have 2 connection of wifi 250MB and 500MB...” do you mean that you have 2 ISP lines of 250Mbps and 500Mbps (please note the speed units being used)?
Even if you were find some way to coalesce the bandwidth of the two, which is a mini-project of its own, 750Mbps is not going to be enough bandwidth for yourself (the provider) and your 1000+ clients. You have to think about the worse case scenario when all 1000+ clients decide to go online at once. The network will grind to a crawl because of limited overhead bandwidth.
yes i'm setting up this network to my own.
It's kind of small business. Yes i have 2 ISP lines of 250Mbps & 500Mbps total i have 750Mbps, if it's not enough bandwidth then i can upgrade 250Mbps to 500Mbps then i have total 1000Mbps and i have 800 to 1000 clients.
let me explain more "
there is a camp in range of 1KM  and camp have 200 rooms each room consist of 4 or 5 people.
I can setup a LAN network 1 router in each room and 200 routers in whole camp but that's too complex for me to handle.
so, i want to setup outdoor wifi network use 2 or 3 outdoor antenna and provide wifi to each person.
what type of wifi outdoor antenna i need to use?
How to setup and manage this network?
Again, as I stated before, this is a large project and I would encourage you to employ a firm that deals with such setups to at least assess your needs (from bandwidth to hardware) and how you're going to manage it.
First of all, I would suggest you dedicate an entire ISP line for this project. You should approach your ISP to determine the business accounts available and what they can provide. You just don't need massive download bandwidth; you also need a lot of upload bandwidth. And you might need to notify them that you'll be using their connection in this way or else you might be flagged for high bandwidth usage and reselling without permission.
In this scenario, Ubiquiti hardware might be what you need. In summary, you'll need a point-to-point (directional) wireless bridge to get the signal that far then distribute the signal (omni-directional) to your clients. The latter might be best set up in a point-to-multipoint configuration with clients using individual airCubes in their rooms, for example. Or you might just choose to use several outdoor antennae which will eliminate 1 more piece of hardware to manage.
Please refer to the Ubiquiti Community forums to get specific help.
Thank You
